M F 2135 who know about one
Snowey
12-31-2003 10:11:10
Help My dealer told me at the time I ordered a service manual and operators manual that my tractor was a 230 industrial he used the serial numbers of the tractor . But the tractor was not a 230 as oil filter did not fit for a 230 . Now dealer stated tractor is a M F 2135 industal do I need new books for a 2135 or is most of 2135 same as 230 . If you have used a 2135 let me know all about then as in problem or good or bad . Thank You Snowey
richard
01-02-2004 14:56:20
 Re: M F 2135 who know about one in reply to Snowey, 12-31-2003 10:11:10
As far as I can remember the 2135 had a spedometer and dual brakes (seperate drums for parking and service brakes)a bit higher road speed and yellow paint,all the ones we got in the U.K. were Perkins A.D.3-152 engined,they also offered a 2130 based on the 130 tractor. Otherwise the same as the agric tractor,the instruction book for our (1966) 135 agric tractor also covers the 2135.
Whiskers
01-01-2004 04:39:34
The 2135 is the Industrial version of the 135. They were also made in a model 20 (later version) Most everything is the same as a 135. The rear tires usually are 24" rather than 28". The front axle is non adjustable and usually built heavier. Most 2135s have a shuttle shift trans.
Snowey
01-01-2004 04:48:55
 Re: Re: M F 2135 who know about one in reply to Whiskers, 01-01-2004 04:39:34
Whiskers Thamk You for the report on 2135 question do I need new manual I have a manual for a 230 . Hope some one can help me on that . Snowey
mowr
01-02-2004 06:02:35
 Re: Re: Re: M F 2135 who know about one in reply to Snowey, 01-01-2004 04:48:55
I'm familiar with the agricultural 230 MF but not an industrial 230. If your books are titled 'industrial 230', I don't know the answer to your question. If they simply say MF 230, I believe you will find them useful for all major components except, perhaps, a shuttle transmission. All the 2135's in the fleet I worked with had the six-speed (non-shuttle) transmission with two-stage clutch, and the adjustable front axle just like the 135. The only differences that I know of were the model number, the yellow paint and higher gearing for a faster road speed.
Whiskers
01-02-2004 05:13:14
Snowey - I am not familiar with the 230. The Z134 Continental engine was used in lots of machines, welders, pumps and several different makes of tractors. They are as common as dirt. Be careful and do not let it get overheated. They will crack between the cylinders. The power steering cylinders are a bit pricey. Just replaced one at $215.
mowr
12-31-2003 11:14:57
The 2135 is an industrial version of the 135. Good reputation, easy to get parts for new or used. If I had to name one weak point, it would be the steering, in my experience.
Dick Krieger
01-01-2004 18:36:49
 Re: Re: M F 2135 who know about one in reply to mowr, 12-31-2003 11:14:57
Hello all & Happy New Year.
I am currently rebuilding a MF 2135 Turf Tractor from the "ground up" I would appreciate any contacts from those who know this tractor and any tip and/or secrets for successful rebuilding of this unit. I was unfamiliar with this tractor until recently and know it is basically a HD 135 with P/S, Diff Lock, Foot Throttle, and Live PTO. It has the Continental Z134 gas engine and had a ton of hours on it when I got it. I heard that there was a weakness in the engine oil pump drive design and that the tractor had P/S problems, but as yet, they are unidentified to me. Hope some folks out there can help me.
Thanks in advance to those who respond.
Dick Krieger
mowr
01-02-2004 06:22:08
 Re: Re: Re: M F 2135 who know about one in reply to Dick Krieger, 01-01-2004 18:36:49
I believe you will find lots of info quickly by doing a word search on this forum (examples: 'Continental oil pump' and '135 power steering').
Snowey
12-31-2003 12:39:27
Mowr Thank you for fast reply . Dealer that got tractor from did not know what it was called . He called it a 200 that is the numbers of the loader . My dealer look up the numbers on tractor called it a 230 later found out not a 230 but a 2135 . Glad it's a good tractor I changed trany rear end hyd oil and motor oil I need to change loader oil now . Hope it a good tractor for me . Thank You for fast reply Snowey
PS do you know if I need new books for 2135 ?
