Dennis and Big Dean-Stuck Diff. Lock
Don H
12-28-2003 20:25:57
I was reading the posts below about the Diff. lock and I have a question. I have a 150 and 165 and both have a problem with the shafts. I have jacked the right side of the tractor up and soaked the shaft with PB Blaster but they are still way too tight. I can step on the lock pedal and it engages. I have to pull up on the petal or pry up on the petal with a 2x4 to get it to disengage. Is there an easy fix?
Dennis
12-31-2003 16:32:15
 Re: Dennis and Big Dean-Stuck Diff. Lock in reply to Don H, 12-28-2003 20:25:57
I had a chance to check the locking pedal tonight and found that it is still securely positioned on the shaft and their does seem to be a light tension on the pedal, like it is still attached to something in there. If I pull the pedal up it stays in the up position it just doesn't unlock the wheels. So I'm still stumped. Thanks to all who had replied to this thread, and A Happy New Year to All
Big Dean
12-30-2003 15:00:17
Don is it the shaft going into shift fork where it goes through the case binding up or is it the pedal binding on the shaft it rotates on. I have seen them bind in both places
Don H
12-30-2003 19:53:47
 Re: Re: Dennis and Big Dean-Stuck Diff. Lock in reply to Big Dean, 12-30-2003 15:00:17
Thanks for the reply Big Dean, I would have answered earlier but I took my mule on a 15 mile ride today. Ouch!! The pedal is tight on the shaft-I have tightened it. I believe there is rust between the shaft and the housing. It can be moved but is very stiff. I just wondered if there was an easy fix. Thanks for your time!
Try...
12-29-2003 13:42:50
...backing up about 10-15 feet and pull up while you do it, shouldn't have to pry it up. Maybe you need to use it more, ours work better when they are used a few times during the day.
Dennis
12-28-2003 21:04:41
In my case the the pedal moves free, there is no resistance on it at all but it still won't unlock.
Casey
01-02-2004 09:04:53
 Re: Re: Dennis and Big Dean-Stuck Diff. Lock in reply to Dennis, 12-28-2003 21:04:41
On my 165 it never unlocks after it is released until I brake left or right. It has always worked that way, most of the time it's no problem but once in a while I don't want to brake for one reason or another (row-crops). Never been serious enough of a problem do anything about it. I am curious though.
Big Dean
12-30-2003 15:10:10
Dennis if your shaft that goes in through the case to the shift fork is free & it is still lock in then you either have the roll pin broke or fell out that holds the fork to the shaft or you have a broken shift fork either one you should repair it before something goes through the ring gear & pinion & really does some damage.
jake
12-30-2003 06:50:22
perhaps the pedal has came loose from the shaft? just a guess...
Don H
12-29-2003 18:16:11
My lock engages and disengages as it should. There is just way too much resistance where the shaft goes into the housing.
