MF 135 (gas) Power steering
Ken
04-16-1999 11:57:52
Help! Heard a ping then no power assist. Pump appears o.k. What could it be? Is there something simple that I'm missing?
Mark
04-16-1999 18:38:51
 Re: MF 135 (gas) Power steering in reply to Ken, 04-16-1999 11:57:52
"Ping" sounds like something broke. I'd guess it's internal probably the pin that connects the power assist gear rack to the hydraulic cylinder. It also could be the gear rack itself which tends to break out around the pin. There is a cover plate on top of the gear housing held in place with four flat head socket screws. You can remove this plate and look inside. If the pin or gear rack is broken, you should be able to see it.Let me know how you get along.
OtisMadden
03-20-2000 07:42:35
 Re: Re: MF 135 (gas) Power steering in reply to Mark, 04-16-1999 18:38:51
I am looking for a power steering unit for a MF 135. I need the complete unit pump and all as my tractor has manual steering. I don't want an add on kit.
Gerald
04-16-1999 19:32:06
I broke the piston rod of the power steering cyclinder on mine once. A good machine shop made a new one far more reasonably than the price for a complete assembly from MF. I think mine was caused by the left drag link clamp catching on the clutch shaft.
Gerald
steve
03-11-2000 05:50:18
 Re: 90 in reply to mic, 02-19-2000 20:36:26
A super 90 WR is a super 90 western wiich does not have an adjustable front end
