Trade 8N for Massey 50, 65
Jon from WI
12-27-2003 19:52:42
It sounds like either the MH 50 or MH 65 would make an ideal replacement for my Ford. What years were these models made, and was power steering standard equiptment? Also what is the actual HP on them, and is there any advantage/disadvantage to either? I am willing to take my time for the right machine. Even tho the Ford is limited, it is solid and works for blading snow until spring when I really need a bigger tractor. Thanks!
Tim
01-02-2004 09:22:47
 Re: Trade 8N for Massey 50, 65 in reply to Jon from WI, 12-27-2003 19:52:42
Another comment; check out a Massey 135 diesel.
I own a UK version with the heavier front axle.
These are short; similar to the old Ford but
with many advantages! Better gear selection,PS.,
diff. lock,live PTO, Great on fuel(diesel)
Much more power,(38)underrated!
The UK version will handle a loader better and
most have P.S.
TIm
01-02-2004 09:14:31
The MHF-50 or MF65 are a good choice. The horsepower of these are 40 and 50 if diesel;35 and 45 if gas. Most don't have P.S. but I would want this if you ever install a loader. They both have a heavy enough front axle for a loader.
The transmission is ok. but sometimes will lock
in gear but this can be solved by undoing the fillerplug at the top beside the shift levers,
and prying the gears over that are locked(stuck).
I have owned a 65' diesel for nineteen years. It was very strong and parts weren't hard to get like
other uncommon brands that don't exist anymore. The only thing you might want to do is put a car
alternator on it so the battery will always be well charged. I used mine at nights a lot to plow snow and this cure worked good! Send me a message sometime and we can discuss further issues!
who wouldn't?
12-28-2003 07:15:00
50's and 65's were good solid tractors. Multipower was a distraction, I prefer the straight 6 or 8 speed.
Hang
07-24-2004 05:40:54
 Re: Re: Trade 8N for Massey 50, 65 in reply to who wouldn't?, 12-28-2003 07:15:00
I am planning buy a MF50, but it has a transmission broblem. The current owner says the converter(trnasmission) has to be replaced. Can I know what does it really mean? Where can I look for parts for MF 50s.
old
12-27-2003 20:32:04
Sorry guys, You might try looking in to an Oliver they pull good but can be had a little cheaper then most I know of 2 1650 olivers for $4500 each and they are around 60HP live pto etc.
