Loader
JB
12-23-2003 09:00:44
I recently bought a MF-202 that has a front end loader on it,does the transmission,hydraulc system and differential all come off the same dipstick? Also how does one know if its mineral oil or regular oil? When draining the system how does one get the oil out of the hydraulic cylinders? Thanks
Iowadave
12-24-2003 08:13:32
 Re: Loader in reply to JB, 12-23-2003 09:00:44
JB,
I bought my 202 2 years ago, just finished rebuilding the engine and front end. Feel free to email any questions. Would highly reccomend purchase of the manuals found on this site. I got the owner/operator, service, and parts manual for the tractor and the service manual for the loader and they're all gotten a work out in the last year. You're missing dipstick shouldn't be hard to make, I'll take some measurements while on holiday next week and post here. May be awhile, my home computer is down and I'll be doing some traveling till mid Jan
Iowadave
12-23-2003 09:13:13
JB,
It's likely a model 100 or 200 loader. It's driven off of a front mounted hydraulic pump (Behind the front grill). Either the left or the right loader side frame (whichever one has the spool valve mounted on it) is the hydraulic fluid reservoir. Should be a cap on top of the reservoir side frame (Just above the spool valve). It unscrews and serves as a fill point and has a dipstick hanging from it. Depending on the model/age of the loader, there's a filter canister either hanging off of the side frame serving as the reservoir, or up front next to the pump. The transmission and differential (& 3pt pump if it has it) share fluid. Don't quote me, but I think the trans/dif holds about 8 gallons, the hydro reservoir about 6. The side frame serving as the reservoir has a drain plug and a suction hose fitting for draining.
JB
12-24-2003 07:54:37
 Re: Re: Loader in reply to Iowadave, 12-23-2003 09:13:13
Thanks for the response Iowadave. This is my first
tractor and I have a million questions.I found the
place where the dipstick is supposed to be for the loader, the cap and everything is there but no dipstick. The loader is a 200.I found the drainplug and there is another plug also,I guess that would be for the suction hose fitting.Have a happy holidays.
JB
snowey
12-28-2003 05:46:53
 Re: Re: Re: Loader in reply to JB, 12-24-2003 07:54:37
J B The top plug is for return for back hoe on the tank fram . Top of tank is fill site with breather my dealer stated to fill 1/2 full about right for 200 loader if dip stick missing use clean stick to see how full your tank is . Snowey
PS my 200 loader is on a 230 tractor M F note loader was bult by other than M F for M F
JB
12-28-2003 06:10:04
 Re: Re: Re: Re: Loader in reply to snowey, 12-28-2003 05:46:53
Thanks for the responce Snowey. How do you get all of the oil out of the loader when you change the oil?
JB
Snowey
12-29-2003 03:19:47
 Re: Re: Re: Re: Re: Loader in reply to JB, 12-28-2003 06:10:04
J B Drain plug is under loader frame not far from your right foot if you are driving tractor , look under frame to loader it has a square drain plug . Befor you drain put bucket on ground tip bucket back so most hyd oil in the tank , stop motor and block tires no roll away needed as you may be under tractor .
Snowey
12-29-2003 15:48:56
 Re: Re: Re: Re: Re: Re: Loader in reply to Snowey, 12-29-2003 03:19:47
J B How did you make out with your loader . Snowey
JB
12-30-2003 23:39:53
 Re: Re: Re: Re: Re: Re: Re: Loader in reply to Snowey, 12-29-2003 15:48:56
I am doing okay with my loader but I am cleaning up an old hedgerow and the ground is to wet to use the tractor. I am learning about tractors and they are amazing. Thanks for the reply.
JB
