ring gear
marlowe
12-18-2003 16:24:36
i know i should not post this here but i need this fast RING GEAR FOR 44 SPECIAL 4 CYL. 277 gas THANKS and sorry
marlowe
12-18-2003 18:59:57
 Re: ring gear in reply to marlowe, 12-18-2003 16:24:36
i have one on the way and thanks to all that took a look.thank you JIM from minn.the world of the net is sure great!!
fasting
12-18-2003 18:31:28
Marlowe, what is the S/N of your Special? If 55113, or up, you have the upgraded pinion shaft,
heavier carrier bearings. Ring gear from a
333/444, if NOS interchange, but wear makes for a
added variable here. You chipped the ring, but the pinion is 'perfect'? Jockeys usually will only
sell the pair. The pair would be a 'deal', at $150
Labor makes the gear cost a $100. or more. They
are out there, better to pull it yourself, but
driving 400 miles is a bit extreme. Let us know...
marlowe
12-18-2003 18:54:56
 Re: Re: ring gear in reply to fasting, 12-18-2003 18:31:28
sorry i should have said fly wheel ring gear for the starter thanks any way. got one on the way
