33 stuck in 1 st. gear
mark
12-15-2003 15:16:19
i have a 1952 mh. 33" and it is stuck in 1 st. gear . anyone have any ideas or pointers before i start tearing her apart? thanks mark.
slowsmoke
01-01-2004 07:28:43
 Re: 33 stuck in 1 st. gear in reply to mark, 12-15-2003 15:16:19
Pull the shift rod cover off (under fuel tank, front wall off tranny) tap the center shift rod back. this should give you nuetral. pull shift lever off, and weld up the ball on the end off the shaft.(just needs built up a little, grind off any nicks. Good luck, Don
mojohn
12-15-2003 15:55:17
contact Big Dean's web site. he can tell you how to unstick it
C. T. in Oklahoma
12-15-2003 17:53:44
 Re: Re: 33 stuck in 1 st. gear in reply to mojohn, 12-15-2003 15:55:17
I second mojohn's suggestion. It is the first item on page 2 of Big Dean's web site. My 35 has gotten stuck in gear several times and as mechanically challenged as I am, I have been able to correct the problem. C. T.
