Massey Harris 44 as a bale tractor
Jim
12-13-2003 23:33:21
I plan to bale some hay next season. I have older equipment (understatement of the year)and none of my tractors have live power.
I need to know if a MH 44 Special 4 cyl. will handle a small square baler (70 pound twine tie)
Any information would be appreciated.
Jim B.
12-18-2003 19:14:58
 Re: Massey Harris 44 as a bale tractor in reply to Jim, 12-13-2003 23:33:21
Should have more than enough power. I use a Massy 33 with an (as old) IH baler. Hand clutch to disengage wheels is better than trying to get it out-of-gear when the baler gets overloaded. I find the location of the PTO shaft (higher above the drawbar than most any other brand) puts an extreme angle on the shaft making it complain alot when turning.
Brad
12-15-2003 22:52:03
Your 44 should work well with a baler. I have pulled my 336 JD with our 44 may times. Even windrows are important but they are with any baler.
Good luck
Brad
BONE
12-15-2003 00:21:13
it should have more than enough power to do that job, already broke 2 pto shaft brush hogging... get over running clutch and put it on the pto shaft...
SBONE
Chris Brown
12-14-2003 14:53:47
Sure it will,your 44 has near 50 hp.I use a 2N ford with less than half that much power. start out in 1 st gear and out of the windrow,let it get up to speed before it gets into the hay .
fasting
12-14-2003 12:42:27
That 44 Special you bought with Hitch-All, did
not have a lever on the right, between the brakes
and fender for live PTO clutch? It was an option,
but most Specials came through with it. Running
70 lb. bales is not difficult for the Special, but
inching the over ride clutch eases the operation
considerably for you and the transmission. Though
about a two day 'sweat-labor' job, finding a parked Special, with live PTO clutch, to swap
transmission cases, gives you the convenience. It
is easier to change cases, than pull the brake &
live clutch assembly. Avoid any different models
than what you have, headaches mushroom, due to subtle changes. The case with axles is about $200.
bob
12-14-2003 07:04:46
it will work fine used my 444 on baler this summer and did okay like other post said some times you have to kick out off gear in heavy hay but has plenty of power
marlowe
12-14-2003 04:51:02
a 44 special should have live power in the hand clutch?are you sure you have a 44S. we used ours and it worked just fine but was a little fast on ground speed in heavy hay
Merle
12-14-2003 03:55:45
Jim
We would use our 44's on the baler when the big tracors were tied up with other duties. Will have to admit the 44's wern't my first choice and I learned to shift out of gear REAL FAST to keep the baler from slugging.
Merry Christmas to all
Merle
