135 Steering problem
Gregg in Arkans
12-09-2003 13:52:33
Manual steering-When wheels are turned left, right wheel won't return to right. You can push with your foot on linkage and right wheel will snap back and be O.K. 'til you turn left again. HELP, Please!
parts man
12-11-2003 19:50:41
 Re: 135 Steering problem in reply to Gregg in Arkansas, 12-09-2003 13:52:33
Your right steering sector is bad, probably broken teeth. You need to take the steering box apart to find out what is wrong.
Gregg in Arkansas
12-11-2003 20:33:01
 Re: Re: 135 Steering problem in reply to parts man, 12-11-2003 19:50:41
In working with the problem, I found an adjustment nut on the opposite side from the steering linkage going to the right wheel that appeared loose. By backing the locking nut off and adjusting the slotted screw out, I've gotten the wheels to work. I, too, thought I probably had broken teeth but this seems to be working and it kept me from having to disassemble the gearbox. Can you tell me what it is that I've done with this adjustment?
Manuals
12-13-2003 06:01:51
 Re: Re: Re: 135 Steering problem in reply to Gregg in Arkansas, 12-11-2003 20:33:01
You need 3 real MF manuals for your tractor, before you cause more damage than you fix. Operator, Repair, and Parts.
Gregg in Arkansas
12-13-2003 07:27:29
 Re: Re: Re: Re: 135 Steering problem in reply to Manuals, 12-13-2003 06:01:51
Thanks for the suggestions. I've ordered the manuals.
