injector pump
Don
12-09-2003 08:16:52
I have a MF175 with perkins diesel. The injector pump is driping fuel from the small cover plate on the side of the pump. If I remove the cover to install a gasket will I encounter anything held in by this cover? The bolt heads holding the cover have a wire on them to keep from backing out. Any help out there?
Thanks, Don
Don
12-10-2003 14:17:07
 Re: injector pump in reply to Don, 12-09-2003 08:16:52
Thanks for the help Rod and Big Dean.
Found a gasket at local industrial repair today.
MF dealer could not find a part no.
Thanks again, Don
rod
12-09-2003 19:18:00
I tried to make a gasket one time for a cav pump same set up but only two small screws holding small plate on this was a david brown 990 but a CAV type pump. I ended up getting a factory seal as I could not get it to stop leaking think it was about 6.00 canadian for it but that stopped the leak.
regards
rod
Big Dean
12-09-2003 10:22:33
Don that window is for timing the injection pump & the fuel can be adjusted through it but there is nothing that you can hurt be removing it to replace the gasket.
