MF 135 steering gear housing oil.
Mark G.
12-08-2003 17:25:38
I have been rebuilding the steering gear housing on my tractor. What started out to be simple repair became and total rebuild as ps rack broke which broke this, which broke that, we all know how it goes. My question to anyone who has been inside the steering gear housing, what oil or grease is inside. Its to thick for SAE 90 but to thin for # 2 grease. Its been in there for 35 years thought. One book says SAE 90 another says calcium soap grease which is not around anymore.
MF Kid
12-09-2003 07:05:04
 Re: MF 135 steering gear housing oil. in reply to Mark G., 12-08-2003 17:25:38
I told you wrong. I used a good quality moly grease to lube the cavity and parts. Not 90wt.
MF Kid
12-09-2003 06:08:04
Go with the 90wt. Make sure you check the bolts that hold the rack on periodically. If you let them get loose-----Boom! Then you have to do it over again. Seemed to be a problem with this type of gearbox. Getting hard to come by a good one that hasnt been damaged by this problem.
