Timing / Fireing order
edmyers
12-08-2003 10:23:48
Need to know what the fireing order is for a gas continental Z134 ( MF 50 ) 4 cyl. . Also is No. 1
cyl. the first one closest to radiator?
thanks
Oldfarmboy Jim
12-08-2003 20:55:01
 Re: Timing / Fireing order in reply to edmyers, 12-08-2003 10:23:48
Yes, in-line engines number from front to back. Put your #1 cyl on TDC compression and then look at where the rotor is pointing. That spot marks where the #1 plug wire goes when the dist. cap is on. Now pay close attention to the rotor rotation as you turn the key and crank it over a bit. It rotates COUNTER-CLOCKWISE, right? This had me stumped one day when I did a tune-up and put new plug wires on the MF35. Took about half an hour before the light bulb over my head lit up.The firing order is 1-3-4-2. Time it for 6 degrees BTDC @ 450 RPM. Plug gap .025. Point gap .022. You'll save a bundle of time and money if you'll get the operator's and shop manuals. I've saved well over $2,000 on four different tractors (MF35, David Brown 885,IH TD340 and Ford 841) by being able to repair systems and replace worn parts instead of paying someone else to do it for me. Plus, I enjoy the tractors more when I know how they go together, Good luck, Jim
