MASSEY 135 TIRE SIZE, DOES IT MATTER???
STEVE
12-07-2003 17:44:23
I JUST ORDERED NEW TIRES AND RIMS FOR MY 135 MASSEY FERGUSON. I ORDERED 11.2 X 28 BUT THE TIRES ON MY TRACTOR ARE 12.4 X 28. WILL THE SIZE DIFFERENCE MAKE ANY DIFFERENCE OR SHOULD I CANCEL MY ORDER AND GET THE 12.4'S.PLEASE RESPOND
THANKS STEVE
STEVE
12-08-2003 06:48:37
 Re: MASSEY 135 TIRE SIZE, DOES IT MATTER??? in reply to STEVE, 12-07-2003 17:44:23
THAKS EVERYONE I WAS ABLE TO GET THE TIRES EXCHANED BEFORE SHIPPING. I GOT THE 12.4 TIRES THANKS
David
12-08-2003 04:18:11
Only real difference is that 11's will be narrower are so will penetrate into ground a bit more as the tractor weight is spread over a smaller area. In harder ground conditions you might actually get more grip from narrower tyres. On the other hand, with wider tyres the load is being applied over a bigger surface area and so will not tend to shear the soil and break the traction as much. Basically what's best depends almost entirely on ground conditions - and they vary. If you're not working at the limit of traction it probably doesn't matter too much either way. There's also tyre pressure to consider.
I don't see stablility as being a big benefit of the wider tyres. If you are are so getting so near the limit of stability that the difference between 11.2 and 12.4 matters in practice, you are too close. As Jack says, widening the track gives the biggest benefit to stablility.
Jack in NB
12-08-2003 03:58:55
Hi Steve -
We've got everything from 10 x 28 to 14.9 x 28 on our 6 35's and 135's.
The differences are mainly in speed calibration for spraying and fertilizing - the larger sizes cover more ground at the same rpm. The 14.9's set the rear end a couple of inches higher, giving a nose down look. And a bit less ground pressure for travel on soft ground - often a factor on our sod fields.
We set up duals for soft ground, and that's fun - there are 10" rims and 12" rims, and the MF adaptors won't work with the 12" rims. Mixing and matching is tricky, so we can keep some space between the tires instead of having them chafing the sidewalls.
I think, but can't prove it, that the wider tires have a bit less slippage.
The stability Tom mentions - if you're facing this issue - can be addressed somewhat by setting the rear wheels a bit wider.
I guess I'd be less concerned than Tom about cancelling your order!
Tom
12-07-2003 21:30:44
Better change your order. Less traction. Less stability. = less useful tractor. Why change sizes??
