MM v.s MF-85
MoJohn
12-04-2003 18:43:14
will the rear rims off of a MM-G fit a MF-85.both are 3o inch.Thanks
doug@upr
12-06-2003 09:20:07
 Re: MM v.s MF-85 in reply to MoJohn, 12-04-2003 18:43:14
all depends which type of rims are on your 85.
if the rims looks the same they should interchange. for example, a deep well rim has one big rail on the inside that has one driver welded on the rail that would go into a slot in your hub, or there is also double bevel, power adjust and many other rims used on newer tractors, but most likely these two tractors should be deep well rims and interchange. unless your 85 is a row crop tractor in which case you'll have power adjust and i doubt that you minny will match up.
mojohn
12-06-2003 15:35:55
 Re: Re: MM v.s MF-85 in reply to doug@upr, 12-06-2003 09:20:07
mine has power adjust but the ones i,m interested in aren't.could i make them work if i had the hubs
