perkins diesel possible blowby
russ jacobsen
12-04-2003 10:08:42
i have a mf with a perkins diesel that when running seems to build up so much pressure in crankcase that it blows oil out dipstick and filler cap. does anyone have an idea what could be wrong with it . thanks russ
H.T.Hertz
12-05-2003 04:47:34
 Re: perkins diesel possible blowby in reply to russ jacobsen, 12-04-2003 10:08:42
Check the breather pipe running down the front from the rocker cover. If it is plugged with hardened 'mayonnaise' and dirt, the dipstick will pop up.
Alvin n Ms.
12-04-2003 11:57:36
The piston rings are worn, but it may run a while yet, the crankshaft thrust may be about worn out also. I own MF35 that will shoot oil over the hood if you pull the dipstick out with the motor running. Been like that for years. Takes about a thousand dollars worth of parts to properly rebuild, including crankshaft, injection pump,and injector spray nossel repair a must, for a good job. I won't get into labor. alvinnms
