The 3 pt rhythm
RZ(WA)
12-03-2003 11:28:23
I know I need to go through and completely rebuild (along with most everything else on this thing )the 3-pt hydraulic pump. No big deal. However, I am a little curious what part(s)may be causing the 3-pt to shake when parially or fully raised when under load ( as in transporting an implement weighing over 200 lbs )? Control Valves or the relief valve or something else ? I'll be comletely rebuilding the the unit this winter, I'm just wanting to know, for future reference, which part(s)would be the main cause.
The rhythm isn't too bad, just haven't found the right music to go with it.
Big Dean
12-03-2003 17:12:18
 Re: The 3 pt rhythm in reply to RZ(WA), 12-03-2003 11:28:23
That is caused by a leak in the hydraulic system If your has the old control valve with the three sealing washer it leaking is usually what I found causing that problem but it could be cylinder piston rings a scored cylinder a relief valve or possibly all of the above.
