Massey Ferg 50 Hydraulics
Dennis
12-01-2003 14:15:23
Dumb question maybe: Does the massey ferguson 50
model (Gas) 4cyl have a hydraulic outlet to tap a line into for operating hydraulic implments or does a pump need to be added to the motor?
Thank you
doug@upr
12-01-2003 17:52:08
 Re: Massey Ferg 50 Hydraulics in reply to Dennis, 12-01-2003 14:15:23
you can either mount a factory valve in front of the seat, which they are very hard to find. or you can just get a manifold that bolts down to the same spot as the cover that is on your tractor and just plumb in a jobber valve for what ever use that you may require.
your cover that is already on your rockshaft may already have a plug in it, so all you have to do is remove this plug and you should have hydr. pressure. the oil is supplied from your piston pump in the bottom of the rear end. this pumps main use is for the 3pt.
marlowe
12-01-2003 15:45:14
just in front of the set and on top of the trans. is a plate held down with two bolts this is where you mount the auxillary hyd. control valve and this will run your remotes. off hand i don't know where you can find one
Dennis
12-01-2003 18:21:20
 Re: Re: Massey Ferg 50 Hydraulics in reply to marlowe, 12-01-2003 15:45:14
Thank you for your answers and the time you took posting.
They answer my question.
Thank you again.
Dennis
Ron
12-02-2003 12:08:48
 Re: Re: Re: Massey Ferg 50 Hydraulics in reply to Dennis, 12-01-2003 18:21:20
Dennis: Try e-bay motors under tractor parts for a remote.
