MF 204 Forklift steering column
Steve G.
03-07-2000 22:40:20
This 204 forklift has a steering column in which a chain runs through three sprokets to reroute to the original steering column. I had pin shear off inside the column that I replaced. But while removing the case that covers the chain and sprokets I did not pay attention to how the chain was assembled. There is noting in the I&T Shop Service manual for this steering system. I have put the thing together five times only to have chain come off each time. As I have assembled it each time (it has a 36" long cast iron case that bolts on to a plate) I have noticed the chain to be somewhat lose. What I wonder is possiable that the outer part of the chain is suppose to rap the center sproket instead of the inner part (on both sides) of the chain for which I have installed it each time. Any help I would greatly appreciate. Thanks!
Randy Mansfield Jr
05-29-2003 16:12:01
 Re: MF 204 Forklift steering column in reply to Steve G., 03-07-2000 22:40:20
your chain goes around both end sprockets and then goes to the inside of the middle sprocket on one side. It shoud make kind of a slight c shape when in stalled it is possible however that the chain is streched.
