Fergusson 35 rear wheels Gettin em loose!
HootisMN
11-22-2003 07:21:04
Any words of wisdom for getting those clamp bolts loose for adjusting the rear tread width. I,ve tried heat, oil, BIG wrenches, nothing works some of the bolt heads even broke off. THnaks
Joe Ferguson
11-24-2003 13:37:32
 Re: Fergusson 35 rear wheels Gettin em loose! in reply to HootisMN, 11-22-2003 07:21:04
Hi Hootis
Are your wheels spinout ?
If yes there are latches which turns 1/2 turn "only" to left to loose with special wrench.
If you have bolted center wheels try soaking threads with WD-40 or similar and try with a big
air impact wrench if available.
HTH
Joe Ferguson
Alvin n Ms.
11-22-2003 16:21:47
A good impact wrench may break them loose. If not take a torch and burn them off,if they have been around salt for years they may need replacing anyway. I assume yours doesn't have the deluxe spinout wheels .
