Compression ration to PSI Formula
George in Mi
11-20-2003 16:36:43
Anybody know, offhand, what the conversion for compression ration to PSI is? Had it somewhere, but can't find it. Hope that's clear, I mean the PSI corresponding to numbers in the ration. That is, in a 7:1 ration, how many pounds for each of the numbers in the seven.
Thanks
George
Jerry/MT
11-20-2003 18:23:15
 Re: Compression ration to PSI Formula in reply to George in Mi, 11-20-2003 16:36:43
As I recall, the equation is p2/p1 = (v1/v2)exp1.4, where v1/v2 is the compression ratio, 1.4 is the specific heat ratio for air at 59 oF and p2/p1 is the pressure ratio assuming and isentropic compression. For a compression ratio of 7.0, p2/p1 =12.245 and at p1=14.7 psia, p2= 224.1 psia. You won't see this on your compression guage, though. Remember the valves are not closed for the full compression stroke and there are pressure losses in the induction system (air cleaner, carb, intake manifold, and intake valve.) Hope this helps.
Gavin M
11-21-2003 02:35:29
 Re: Re: Compression ration to PSI Formula in reply to Jerry/MT, 11-20-2003 18:23:15
Sounds about right. Also assumes ideal gas behavior, which is reasonable for air, totally wrong for the fuel. At an A/F ratio of say 10:1 there is about a 9% volumetric (ideal gas) concentration of fuel, which will bias the compression test result lower unless the carb is off the engine. There is some dependancy of Cp/Cv on temperature. The "Compression Ratio" is not that at all, it is a measure of volume ratio, not pressure. As such the pressure losses (volumetric efficiency) will affect the amount of cylinder filling, as Jerry/MT said.
