Blowing Oil
Hoot
11-19-2003 11:00:38
MF 135 blowing oil out dip stick hole, engine just rebuilt not more than 50 hrs on rebuild, think rings not seated yet.
David
11-20-2003 05:10:52
 Re: Blowing Oil in reply to Hoot, 11-19-2003 11:00:38
Is breather clear? Was it fitted with new liners or just new rings? If was just new rings fitted into old liners that had a wear ridge, the ridge might have damaged top compression ring(s).
old
11-19-2003 18:20:17
Well its either the rings not seating right yet or the rings not put on right. If its that they haven't seated yet you need to make it work some and run it slow to high never keep the RPM the same for long times. If its that the rings aren't on right you need to take it apart again, the rings should not have any of the gaps lined up at any place on the piston. Hope this helps
