MF 135 Temperature
James, NC
11-18-2003 17:14:01
I have a MF 135 perkins gas. It smokes a little, and an older gentleman in my hometown that has worked on Masseys for years ask me what the temp was. I said it runs about 165. He suggest trying to get it to about 185-190 and the engine rings and sleeves will seal better. Any comments. Thanks
Hoot
11-19-2003 09:07:51
 Re: MF 135 Temperature in reply to James, NC, 11-18-2003 17:14:01
Might be what I need to do 135 with continental 4 cylinder engine with less than 50 hours on complete rebuild, tractor spits oil out dip stick slightly. Maybe rings not seated.
old
11-19-2003 06:21:24
I believe he is right if you get it warmer things more and seat better. Any time I start up an engine that has been stuck that I have unlocked I don't even put water in it the first time that way it gets almost to hot. That seems to pop the rings loose and I have yet to need to replace the rings because of them sticking. Hope this helps you a little
