135vs. woodsplitter
Dozin hal
11-16-2003 09:43:29
I have a gas 135 that has I use to split wood with. I hooked up the remotes and pulled the trigger this season and the cylinder worked but it will not split any wood, when it meets any resistance it stops. Also, ever since I had this rig, when the ram meets the wood, the lift raises to the top, then it splits the wood, but not this year. Ichecked the oil and everything. Does anyone know what is stuck or worn out? Thanks
CH
11-16-2003 11:08:16
 Re: 135vs. woodsplitter in reply to Dozin hal, 11-16-2003 09:43:29
Will you 3pt still lift 2000 lbs? If the 3pt is still strong, it could be a misadjustment in the control valve and you can't go into constant pumping. More likely a bad relief valve.
