MF35 - 202 Workbull power steering
George in Mi
11-14-2003 11:17:44
Badly leaking left front wheel power steering cylinder on my 1960 MF 202. Are these the same as on MF-35?(if 35's had ps). Are they Interchangable?
I'd like to try to repair it. How does the cylinder come apart. Have removed snap ring and outer seal cover. Is there a screw-on retainer holding the outer seat, etc, in? Or other?
Lastly, all else failing, anybody got a source/suggestion for replacement?
Thanks
George
George In Mi
11-16-2003 18:48:01
 Re: MF35 - 202 Workbull power steering in reply to George in Mi, 11-14-2003 11:17:44
Ed,
The email link on my system doesn't work, I'll need your email address to contact you. You can contact me at [email protected]
Regards
rod
11-14-2003 16:20:06
send me an email I will scan and send you the parts picture of the steering cylinder and the MF part numbers ok
regards
rod
George in Mi
11-14-2003 19:01:16
 Re: Re: MF35 - 202 Workbull power steering in reply to rod, 11-14-2003 16:20:06
Rod,
Can't thank you enough. Problem is, for some reason my computer tries to reboot AOL when I click on your address, but I'm already online. Must be something in the configuration, which I 'll have to figure out. In the meantime, my email address is [email protected]
Thanks again,
George H
rod
11-14-2003 19:06:20
 Re: Re: Re: MF35 - 202 Workbull power steering in reply to George in Mi, 11-14-2003 19:01:16
I sent you a scan of the cylinder did you get it?
regards
rod
George in Mi
11-14-2003 20:15:26
 Re: Re: Re: Re: MF35 - 202 Workbull power steering in reply to rod, 11-14-2003 19:06:20
Rod
Just in case you didn't get my confirming email, yes, I got the scan, and Thank you very much
George
