MF 35 Injector timing
George Robinson
11-11-2003 21:59:42
Gday, I have just bought a MF 35 four cylinder Diesel. It is hard starting and has a popping like noise in the intake manifold. I think the injector timing may be retarded. Can any one please tell me the procedure to check the injector timing.
Thanks George R
David
11-13-2003 05:21:11
 Re: MF 35 Injector timing in reply to George Robinson, 11-11-2003 21:59:42
Someone will have the correct procedure but I think you many need some special tools. As a first effort I'd suggest setting pump with securing bolts central in slots and seeing if that helps. You can also rotate pump slightly with tractor running to see what effect it has. Maybe its a leaky valve?
George Robinson
11-13-2003 12:04:32
 Re: Re: MF 35 Injector timing in reply to David, 11-13-2003 05:21:11
Thanks David, I removed the head and found a leaking inlet valve.
George R
David
11-14-2003 06:22:44
 Re: Re: Re: MF 35 Injector timing in reply to George Robinson, 11-13-2003 12:04:32
YESSSS. I got it right for once!
