Good perkins engine
jake
11-11-2003 20:15:32
Hello, I am looking at re-powering a 1950 ford truck and would like some input on what kind of perkins engine I should choose. Which ones make the most power for the weight. I have been told that a 354 would work well for my project. Does anyone know the appoximate weight. I was thinking of using a 354 with an oliver hydral shift(over/under) hooked to a 5 spd. What are your opinions. thanks Jake
Darren D.
12-10-2003 17:03:04
 Re: Good perkins engine in reply to jake, 11-11-2003 20:15:32
My folks ran a turbocharged 354 Perkins out of a 1130 Massey Ferguson in their deliver truck from 1969 until about 1988. It was a 1965 5000 GMC with a roll back bed (that they also built). That truck empty weighed 18,500 lbs.. The engine will weigh about 1300 lbs.. They used a 5 speed behind it along with a aux. over under. They used a 17" Perfect Circle bell housing from the engine and mated it with a 19" Perfect Circle bell housing to the transmission. They made an adapter plate to go from the 17" to the 19". They also had to make a spacer for the throw out bearing. The turbocharged 354 made about 33% more hp than the non turboed 354. That ol truck sounded good! They still have the truck. Good luck with yours.
Tom S.
11-12-2003 06:07:36
How heavy is this truck, and will it be used off or over the road?
I might consider a late model Detroit or Cummins and Allison.
Might be much simplier installation.
Tom S.
jake
11-12-2003 06:30:47
 Re: Re: Good perkins engine in reply to Tom S., 11-12-2003 06:07:36
Tom,
This truck is a 3/4 ton truck. I was kind of wanting to put something in other than a cummins, and a gm would just be wrong. But I thank you for your suggestions. If you have any other ideas shoot them at me. Thanks again for your response. Jake
