Charging info Help
country
11-07-2003 19:46:05
Hi I have a 135 diesel and converted to altnator and is not charging.The NAPA Man told me to do the following.Install altmator and he sold me a single wire alt AC Delco and the wire pluged into the alt and the other end of the wire went to the alt bolt.And take another wire from the bolt to a battery source well went to the + side of the amp guage on the + side is the alt. wire. dash wire, and a battery wire.& on the - side is the light fuse wire and might be the switch wire not sure now without looking.I was working with the lights on and was draining to battery so looks like back to the drawing board. the voltage reg has been took off. amy help will be greatly appreciated.would the rotation of the alt make a differance? Thanks
Country
Allan C
11-11-2003 19:32:55
 Re: Charging info Help in reply to country, 11-07-2003 19:46:05
Oops forgot the rotation question. Alternators are made for clockwise rotation when looking at the pulley end, but theoretically should work either way.
rod
11-08-2003 06:42:54
I have one wire alt on my 203 it has only one wire to the starter and that is it you have to rev engine to 1500 rpm to get alternator to excite when you start it to get the thing to charge once you do that it is ok. regards
rod
Allan C
11-11-2003 19:29:51
 Re: Re: Charging info Help in reply to rod, 11-08-2003 06:42:54
I don't get the part about the wire to the bolt. The one wire has to get to the + side of the battery, usually through the ammeter. If It's a straight hookup to the solenoid wire you won't read whether it's charging or not. Be sure it's neg ground. Remember it's a one wire altrnator - one wire to the - side of the ammeter. that's it!
