hydraulic system of MF 285
Hamid
11-05-2003 00:59:04
Dear sir
Now, I am designing the Hydraulic System of a special machine that connect to Tractor model MF 285.
This machine needs two kind of pump.The first pump turn by power take off shaft (P.T.O.).
I want to use Tractor Hydraulic System for the second pump.
The first pump and it�s tank and their base move up and down by tractor behind arms.
Tractor behind arms must be up When the Tractor Hydraulic System work. If it�s possible.
Best Regards
Alvin n Ms.
11-05-2003 13:03:13
 Re: hydraulic system of MF 285 in reply to Hamid, 11-05-2003 00:59:04
Will work kind of slow of course, only if you tap into the hyd/ pressure and have remote control valves, You can have as many valves as money and time will aford, then rig up a way to dump the oil back into tractor. I have seen people drill a hole in the oil filler plug. Maybe someone will add to this. Let us know what it is that you have invented.
Alvin n Ms.
11-08-2003 20:00:11
 Re: Re: hydraulic system of MF 285 in reply to Alvin n Ms., 11-05-2003 13:03:13
A pto pump is severly in the way, if you are going to use the three point lift system. In front of engine is the most usual place to locate an external pump. Plus higher volume, and turns at the engine speed.
