TO35 ORIGINAL TIRE SIZE AND TYPE
TONY
11-03-2003 14:43:52
I have a Massey-Harris Ferguson T035 that has 7.50 x 16LT tires on it. I know these are not the original tires. I tried to reverse the rims to narrow the front end and the tires are hitting the ball joint. I was told that the original tire was a 6.00 x 16 3 rib tire, but when I compare the width of the existing tire to the width of the 6.00 tire, it doesn't seem to be much narrower. I would like to know what the original size is and also what size will allow me to reverse the rims in to achieve a narrower stance without hitting the ball joint. Thank You
TO35
11-04-2003 15:51:46
 Re: TO35 ORIGINAL TIRE SIZE AND TYPE in reply to TONY, 11-03-2003 14:43:52
Tony
Orignal front tire size is 5.50x16 and yes some 6.00x16 5.5 wide with 3 rib tires. Sounds like you do not have the correct wheels if you have them turned around correctly dish (bowl shape pointing inward towards tractor) and the tire is hitting you have the wrong tire size width wise. You can narrow the front by the front axle's just move them in to the last bolt holes.It is not recommended to trun front wheels around because the wheel nut are concave and match the wheel.
If you need to see what it looks like on the lft side of this page is picture galleries click there and look at a to35 picture. If I remeber correctly you front "stance" will be just around 5ft all the way in.
Best wishes
TO
Old Cane
11-05-2003 12:18:12
 Re: Re: TO35 ORIGINAL TIRE SIZE AND TYPE in reply to TO35, 11-04-2003 15:51:46
that's a mighty comfy looking seat!
TO35...look here
11-04-2003 17:17:13
third party image
here's the front all the way in and you can also see the wheels,these tires are 5.50x16x5.5
Old Cane
11-04-2003 08:39:37
I'm not sure on this but I don't think oyu reverse the front wheels. I htink you adjust the width by letting out the axles by using all those bolt holes you see up there.
