Used ATF in fuel to clean injecter
snowey
10-31-2003 17:37:06
Thank you for posting about A.T.F. Used Automatic Tranimission Fluid in diesel fuel for my Massey Ferguson 230 with perkins diesel . I was having a miss at 1250rpm to 1500 rpm a dead spot if brush hog was on tractor only way to go faster than 1250rpm was down hill a light grade it will run up to 2100 rpm . I thought fuel injector was dirty , try other injector cleaner no good at cleaning injector , motor was runing with same with miss . Used one Qt. atf in fuel can then $5.00 of diesel fuel into can put all of it in fuel tank of tractor with 1/2tank of fuel that was in tractor tank . I live in boro. because of residency requirment of my job in town . Started tractor ran 10 min pulled out on my street , tractor runing better as I was driving around development after passing chidren eight times they stop waiving at tractor so it's time to park tractor . Injector are doing better , motor is pulling better , miss is all but gone and it's time to go eat , will try runing tractor more Sat. . Snowey
Rick(ont)
11-03-2003 11:35:34
 Re: Used ATF in fuel to clean injecter in reply to snowey, 10-31-2003 17:37:06
I had the same problem a year ago. I e-mailed big dean and he told me to run a litre of atf in a full tank of fuel. Did that and it ran like a charm. He recommends doing this every 4 or 5 tanks of fuel to keep the injectors clean.
David
11-02-2003 12:30:34
So how much ATF to how much fuel did you mix? Not sure what $5 worth would be in UK. About half a gallon at our prices!
