MF50 $ ?
Tom
03-03-2000 19:32:12
How much is a MF-50 worth with a gas engine (smokes a bit has good compression all cyl 105psi), power steering, tractor is in great shape . Also has a davis quick disconnect loader also in super shape. Thanks
B.C.
03-06-2000 06:35:10
 Re: MF50 $ ? in reply to Tom, 03-03-2000 19:32:12
I think I gave 2200 for ours back in 1982. Guy wanted about 500 more for the loader which was on it, and which I declined. It was a decent loader but I really didn't need it.
There's an access plate below the clutch housing. You might check in there to see if the engine rear seal or trans input shaft seals are weeping oil. Be sure the dual disc clutch (which it probably has) works okay for the live PTO function.
We've fixed things on ours from time to time but have never regretted having it. Has always been a good starter in the winter.
NormZ WI
03-05-2000 07:02:33
I bought my 1956 MH50 for $3200. Good original shape. no blade or loader. Tires a bit weather checked. Started all winter long.
Mike from Ontario
03-04-2000 05:49:09
Tom Up here that tractor is worth betwen $4500 - $6500 depending on condition of tires, paint, motor, etc. That's Canadian so i'm not sure about American pricing, maybe around the same.
Mike Leggett
