MF 235 Won't Start
Steve
10-29-2003 12:02:22
My 235 acted as though the battery was dead and so I had to boost it the last couple of times to get it going, now even with a new battery and a boost it won't turn over fast enough to start. Does this most likely sound like a starter problem or could a bad alternator also be causing the problem. If it's the starter what is likely to be the problem and what is the most economical way to remidy the situation.
Any help appreciated.
Steve
JC
10-31-2003 11:02:14
 Re: MF 235 Won't Start in reply to Steve, 10-29-2003 12:02:22
Sounds to me like your starter needs a rebuild.
It is drawing too many amps. This will put a strain on your new battery, as well as heat up your battery cables. After a rebuild your tractor should start fine.
Most places that do rebuilds will test the starter for free, so that is where to start.
CH
10-29-2003 13:13:13
It's more likely you have a bad connection between your battery and the starter. My alternator doesn't work at all on my 245, but the starter spins like crazy. I just put the charger on it every so often. Maybe one day I'll fix it.
