Massey 255 (help)
Jon
10-28-2003 15:48:00
I am thinking about a 255 Massey Ferguson. It runs and operates really well. Everything works. Good paint and tires. How much do you all think this might be worth? Thanks for any info!
colekicker
10-29-2003 15:47:22
 Re: Massey 255 (help) in reply to Jon, 10-28-2003 15:48:00
$6500. That is about the going rate for a tractor of that age. Gotta remember that it's an MF and some parts get a little pricey. Good thing is there's a lot of aftermarket stuff. Only thing is that they are a little hot in the summer to operate.
Rlach
10-29-2003 10:09:28
I have a 275 which is quite similar; a good working Multi-power is a plus; there is 2 possible engines in this tractor, the 203 CID and 236 CID; 203 is easier to start in winter but has a tendency to vibrate more excessively than the 236; there is certainly a reason why MF switched from 203 to 236 CID. Check hydraulic system before buying.
Just my 2 cents
Rlach
glenn
10-29-2003 07:16:47
which transmission? multipower or the 8 speed standard? I prefer the 8 speed 'cause it's bulletproof.
make sure the PTO will drive a load, the 3 point will lift a load, and the aux hydraulics will lift a load. These tests will verify that the PTO clutch, 3 point pump, and aux hydraulic pump are OK.
I love that Perkins diesel. Starts well in winter and easy on fuel.
Phil in MS
10-29-2003 06:20:10
Jon,
I have a 1975 MF255 diesel row crop (sets a little higher). A dealer told me it might be worth $4,500 in a trade, may be more if good tires. I would not price mine at $8,000 because I would fear that someone would buy it. These are good all around tractors and fitted with a 6 foot bushhog can really work. We have cattle so mine moves hay, rakes hay and bushhog's mostly.
I don't think you can go wrong with this tractor in my humble opinion. Feel free to post additional questions and I will certainly try to answer from my perspective.
Phil in MS (Northeast Mississippi)
