MF135 constant pumping
James, NC
10-27-2003 17:44:43
I just bought my first tractor son this may sound like a dumb question but what is the purpose of constant pumping range.
Alvin n Ms.
11-03-2003 16:08:39
 Re: MF135 constant pumping in reply to James, NC, 10-27-2003 17:44:43
With implements removed, raise lift to up position, the get off and lift up on the lift arms, you should be able to raise them another 3/4 in. If not the pressure is constantly poppin off. Set stop on lift leave so there will be some clearance. I once saw one that had exploded in cold weather, had ice in the pressure rel/valve. Threw bolts and parts a hundred ft. Broke up that thick cast iron lift cover like it was glass. Now I"m a beleiver.
Don-WI
10-27-2003 19:05:25
Comes in handy when a switching block is mounted to put on aftermarket aux. hydrualics, or a loader. Works alright for aux, but for a loader it is rather slow but still works.
Donovan from Wisconsin
