135 Locked in Reverse
Mike
10-27-2003 06:20:49
Was using tractor w/ grader blade. Tractor is now stuck in reverse. Gear shift is in vertical position and will not move. High/low still working as is power takeoff. Any thoughts on how to free? Thanks.
Paul Shallcross
11-23-2003 02:43:55
 Re: 135 Locked in Reverse in reply to Mike, 10-27-2003 06:20:49
This happened to me. take the pin / s out that connect the shift to the gearbox (under the boot)
undo the cover to the left as you look forward. push the gear with a bar to release it. (takes a bit of fiddling and force) repace all when free with new pins for leavers (the worn pins and too fast a shift are the problems)
CH
10-27-2003 06:56:43
Remove transmissiom fill cap to the left of shifter. Using large screwdriver, realign the gears so the shifter slides down the shaft. Usually happens to me in second or third if I don't shift cleanly, not shifting through the pattern.
C. T. in Oklahoma
10-27-2003 16:19:34
 Re: Re: 135 Locked in Reverse in reply to CH, 10-27-2003 06:56:43
If you are mechanically challenged like me, go to Big Dean's web page, first item on page 2 and the instructions are perfect. C. T. Link
