165 multi power
g cole
10-26-2003 05:01:42
If the multi power goes out can't it be bolted together in either high or low and leave it there without having to fix it?
Lee in MI
10-26-2003 11:15:54
 Re: 165 multi power in reply to g cole, 10-26-2003 05:01:42
You still have to take it apart as you would to fix the multipower. Split the tractor twice, once at the bellhouse and once behind the trans. For the most part the cost isn't that much to buy the parts and fix it right. Mainly will need friction disc and sealing rings, and to check a few wear spots. I did mine last winter, works better than when I bought it. Although I will admit I was alittle leary about doing it. Lee
Lee in MI
10-26-2003 11:04:53
Yes it can, you end up in HIGH, Big Dean's cd on the 100 series shows how to do it. Lee
