MF 1130
John
10-26-2003 04:34:01
Hi folks:
There is one of these coming up at a sale in a couple of weeks. It has a wide front end, 20.8 tires, and 4 years on a Perkins overhaul. What are the pro's and con's of this tractor? Can you get a lot of power out of the 354 Perkins? It will be a pulling tractor. What is it worth? I have no idea on the year.
Thanks,
John
Scott
10-26-2003 07:27:15
 Re: MF 1130 in reply to John, 10-26-2003 04:34:01
You cannot go wrong with any 1100 series Massey. I have an 1130 (1969) and I love it. Built typical MF rock solid for many years of service, with proper preventive maintainence of course. As far as power goes, the AT6354 (6 cyl. turbo chged.) you'll not run out of power. Mine runs like a bear w/ plenty of power, and it needs a motor job. The farmer I bought it from ran it a while with a plug missing on the pressure side of the intake, (after the turbo), and either it sucked in a bunch of dirt at idle speeds and chewed up the rings, or it ran too rich under a load due to a lack of manafold pressure and burned the valves/rings etc., or both. It starts hard when cold and smokes a lot, but as I said, it still has tons of power. They are rated for 120 PTO HP. Probably the only thing to check out would be the Multi-Power function, if it's so equipped. This would probably be one of the weakest items in an abused tractor. When in low, the tractor should move and "coast" whenever going down grade. When in high the tractor should move a "half" of a gear faster and the engine should hold the tractor back when descending a hill, as most regular standard shift transmissions would. Also, if you push in the clutch on a hill (w/ MP in high), the transmission should hold the tractor from rolling as if you were applying the brakes. Also, there should be no clutch slippage while in high. As for price I do not really know what they go for. I know they do not go cheap as they are a great tractor. At a dealer I think they go for around $5000 to as much as $8500 for one in good working order with good rubber. I paid $3500 for mine, but the engine needs work (less than $1000 for O/H kit, and I'll do the work myself). The rest of my tractor is in excellent working condition. Also, it has all fairly new (95 % tread) matched stock size/style rubber, and all the options (dual remotes, Multi-Power, power seat, ROPS w/canopy, Cat. 2 3 point hitch). I've been told that this was a very good price, although I'm sure there are just as good of deals out there if you look around. You will not be disapointed with an 1130 Massey. Great tractor. Hope this helps.
Don-Wi
10-26-2003 20:23:29
 Re: Re: MF 1130 in reply to Scott, 10-26-2003 07:27:15
just one comment on the MP- only will hold from rolling back on hill if in forward gear, and opposite for reverse gear.
Donovan from Wisconsin
