MF 65 Deisel
Jim in Oregon
10-24-2003 13:38:06
I have installed new brakes, now I need to put grease in the differential and trans., do I need to pump grease into the axle wheel housing assembly for those gears? Or does it flow from the differential and trans.
Thanks,
Jim
dirtclown
10-24-2003 16:39:18
 Re: MF 65 Deisel in reply to Jim in Oregon, 10-24-2003 13:38:06
By grease I'm hoping you mean mineral oil.
If your refering to the axle planetary it should be filled to the top of the drain hole, which is on the front side. Using the same mineral oil. Let me know how your brakes work, I need to do the same thing.
Jim in Oregon
10-29-2003 16:25:24
 Re: Re: MF 65 Deisel in reply to dirtclown, 10-24-2003 16:39:18
Thanks to "dirtclown" for the info on filling spline gears. I finished installing the brakes and all went well. I installed new grease seals, for 4 of them it was about $90. Brake pads were about $24 each, it took 4 total. If you have a differential lock, make sure you put the snapring on the dirrerential lock shaft as you install the shaft into the housing, you will have to depress the spring (not fun!).
Jim
