MF 165 Front Loader Hydo Problem
Mike Parker
10-23-2003 10:06:18
I bought a MF 165 with new front loader. All working fine.
This week bought bushhog... first use of the 3 point hitch. I have a switch on the hydro system... all worked fine... front loader held position fine while I did some cutting.... but I can no longer get the front loader to function.
I placed the system in constant pumping (and every other variable known to man)... The switch is a lever that has 180 degree option... have tried all three positions. Straight up was position for 3 point operation.
Any ideas... I have the loader on the ground and cannot move the tractor until I get this figured out.
"new to the tractor community"
thanks
MIKE PARKER
Killeen, Texas
Bill B
10-24-2003 20:14:31
 Re: MF 165 Front Loader Hydo Problem in reply to Mike Parker, 10-23-2003 10:06:18
Hi, The two lever on the right, put one in constant pumping , the other all the way back. I asume you have a couple more controls under the seat. The one on the left should be in the middle position and the left one will control up and down. Bill
lonestarjeff
03-21-2004 09:29:27
 Re: Re: MF 165 Front Loader Hydo Problem in reply to Bill B, 10-24-2003 20:14:31
On mine the left or inner quadrant lever stays @ top(constant pumping position), & the right or outer lever does the loader lift & drop all about half way down on the quadrant.
Jeff
