water in transmission, TO-35
Karl
10-21-2003 13:58:48
I have a 1956 TO-35, been in the family for years.
Looking for probable cause for water being mixed in with the 90Wt. Tractor has been out doors the last 6 mo. Can't find my book, Also need to know the capacity of the trans. when I do refill.
Any help would be greatly appreciated...Thanks in advance!
KCB Maine
RogeR
10-22-2003 06:34:34
 Re: water in transmission, TO-35 in reply to Karl, 10-21-2003 13:58:48
Karl;
My TO-35 takes 8 Gals.
Jerry/MT
10-23-2003 15:09:35
 Re: Re: water in transmission, TO-35 in reply to RogeR, 10-22-2003 06:34:34
If you live in a humid climate, water will condense in the transmission case, when the temperatures drop. I kept my old JD 435D covered when I lived near Seattle and the I had to change the fluid yearly to get the water out. I ended up putting a small elbow and pipe plug on the drain so I could just drain the water out.
marlowe
10-21-2003 18:10:46
6 gal. use mineral oil [NOT] gear oil massey no. is M-1103 or GL-1 mineral oil
john(UK)
10-21-2003 14:51:54
Usually leaks in at the rubber boots on the levers..Capacity 32 US quarts from empty. SAE90 oil aove 50F SAE 80 below 50F
Karl
10-23-2003 11:07:22
 Re: Re: water in transmission, TO-35 in reply to john(UK), 10-21-2003 14:51:54
Thank you
Jack in NB
10-22-2003 01:32:30
Hi guys -
There are 6 spots for water to get in:
2 boots around gearshift levers
missing gasket or chewed-up plug on oil filler hole
missing cover on air breather under the seat,
missing oil level dipstick, and most often overlooked,
rubber boot on the top link linkage. And this one is tough to replace.
Call me if you need help to replace it - takes too long to write!
Jack Wetmore in Fredericton NB
