Alternator goes berzerk
CityBoy
10-20-2003 20:03:12
Was making good progress turning the neglected MF35 into a serviceable tractor -- new battery, new gauges, new radiator cap, new antifreeze, new oil and filter, new alternator (10 SI) -- and then a small problem. Warmed up tractor prior to changing oil. When I turned it off it kept running and voltage level shot up past the gauge. Killed it with the choke. Had alternator tested; it's now dead (low voltage). I had run it before with this alternator and it was fine.
I had messed with the wires to the alternator and may have accidentally switched the sense and field lines. Or put another way I may have jumpered the output post to the field connection (#1) rather than the sense connection (#2). Would this have fried the alternator? And if so then why fry only when I turned ignition off?
Allan C
10-21-2003 21:27:48
 Re: Alternator goes berzerk in reply to CityBoy, 10-20-2003 20:03:12
If you reversed the connections you may have fried the internal regulator. They're cheap and easy to change. Make sure you watch which holes the insulated screws go in.
