MF135
James
10-20-2003 17:45:27
I bought a 135 perkins gas, live pto recently, (first tractor)and am fairly satisfied. However after a few hours of working it I started hearing a slight knock with the clutch out. When the clutch is pushed in it goes away. any ideas out there.
David
10-21-2003 03:43:18
 Re: MF135 in reply to James, 10-20-2003 17:45:27
Forgot to also say that some 4 cylinders have a "cold climate" cylinder head that has glow/heater plugs in each cylinder. I have no experience of these but think that the starting might be ok on those ones.
David
10-21-2003 03:45:17
 Re: Re: MF135 in reply to David, 10-21-2003 03:43:18
Oops - added message to wrong thread.
David
10-20-2003 17:58:27
Is it possible that hydraulic control lever is all the way up? (in constant pumping sector) If so it will produce a knock from transmission case as relief valve discharges. This is normal but would cause damage if you let it continue for a long time. It would stop when you push clutch through second stage of its travel (ie. the bit of travel that stops PTO)as this disengages the pump. Just a possibility. Sorry if its not that simple.
James
10-27-2003 17:27:20
 Re: Re: MF135 in reply to David, 10-20-2003 17:58:27
David, I did have the hydraulic lever in constant pumping. when I moved it down to transport the knocking stopped. Thanks for the help
James
10-21-2003 17:47:07
What you say sounds reasonable, but when I hear the knocking in transmission, around the gear shifts, the attachment(s) are either up or down with the clutch out. It only goes away when clutch is fully depress. Isn't the constant pumping sector down instead of up? The tractor is in the mountains on our land right now but am planning to bring home soon to tinker with.Will go up this weekend to try your idea.Thanks for your input
