MF 30B Ind Hydraulic pump shaft
Jim
10-20-2003 13:20:12
The shaft from the engine to the pump is rounded off. The pump is good except for the shaft. Can the shaft be replaced or do I have to spend about $1,000 for a new pump.
I would also need the shaft from the engine. I hope I can find this from a dealer. Was thinking about taking it to a machine shop but don't know if I can get the shaft out of the pump.
Any idea or experiences with this type of problem?
Big Dean
10-20-2003 14:59:00
 Re: MF 30B Ind Hydraulic pump shaft in reply to Jim, 10-20-2003 13:20:12
At one time you could get the shaft to go in the pump if I remember right it came with the gear on it. I don't know if they are still available from the dealers today or not. If your pump has ever been replaced it may be a different pump than the one that came on the tractor.
Jim
10-20-2003 15:58:52
 Re: Re: MF 30B Ind Hydraulic pump shaft in reply to Big Dean, 10-20-2003 14:59:00
Well if I can get the shaft out of the pump I can get it built up and machined if one is not available. Thanks for the info.
How hard is it to get the shaft out of the pump?
How about the connecting shaft from the engine, is that easy to remove?
I have a service manual ordered but won't receive it for a couple of weeks.
marlowe
10-20-2003 17:37:50
 Re: Re: Re: MF 30B Ind Hydraulic pump shaft in reply to Jim, 10-20-2003 15:58:52
you have to take the pump apart to remove the shaft. the shaft and the gear are one and as far as getting shaft built up not real sure they can do it because it hardend steel and will get brittle from welding. the other end is eather a flang with 4 bolts or a left hand thread that will turn out
Jim
10-20-2003 18:42:42
 Re: Re: Re: Re: MF 30B Ind Hydraulic pump shaft in reply to marlowe, 10-20-2003 17:37:50
I am sure you are correct. That makes sense. Thanks for the help! Just have to hope I can get a shaft, May not be the orginal pump so will see. May have to just fork over the money for a new pump.
Guy
11-06-2003 20:37:00
 Re: Re: Re: Re: Re: MF 30B Ind Hydraulic pump shaf in reply to Jim, 10-20-2003 18:42:42
I had my pump shaft done in a machine shop and it worked just fine. Also had a new spline coupling for pump drive shaft installed at the same time. New parts woudn't work any better.
