30B hydraulic pump shaft rounded off
Jim
10-19-2003 18:46:22
This is a front mount pump connected with a shaft from the crank. The shaft on the pump and the connecting shaft are rounded off.
Other than the shaft the pump is fine. Can the pump shaft be replaced or do I have to spend $1,000 for a new pump and shaft from Crank, if I can find one. Seems like there must be a cheaper way to fix this.
Guy
11-06-2003 20:41:48
 Re: 30B hydraulic pump shaft rounded off in reply to Jim, 10-19-2003 18:46:22
Take the pump off and apart and send the shaft to a machine shop to have it repaired. You may want to have a new plined bushing installed at the same time since it most also be worned out. Also, make sure the rubber bushings in the crank adaptor are ok because I think they are the main cause of pump shaft wearing out.
