MF 202 Industrial: Value, Power steering, Another
George Holmes
10-18-2003 15:25:51
Hi,
Just bought a MF 202 loader tractor. Power steering doesn't work, could be oil level. Where is reservoir? Also wondering about the price. I paid $2,300. Finally, three point lift arms don't raise...is there anything to engage before lever, or is it an inside issue? (Good news is, bucket works great, no apparent leaks in that system?
Thanks
Tom
10-18-2003 16:39:33
 Re: MF 202 Industrial: Value, Power steering, Ano in reply to George Holmes, 10-18-2003 15:25:51
George, PS Res. is left front on engine, got to unbolt lid. On mine with dozer blade, the blade control valve is on top of the trans., on the backside of valve kind of under the seat is a push pull valve which switchs from aux. to three point. Don't think you got hurt on price at least where I live.
George Holmes
10-18-2003 18:31:40
 Re: Re: MF 202 Industrial: Value, Power steering, in reply to Tom, 10-18-2003 16:39:33
Tom,
Thanks for the reply. Sounds like the three point would be turned off with the switch you mention, if the auxiliary is turned on. Would the auxiliary be the hydraulic for the front blade? If so, and I hope it is, this might be my problem,
Thanks again...
Tom
10-18-2003 19:24:17
 Re: Re: Re: MF 202 Industrial: Value, Power steeri in reply to George Holmes, 10-18-2003 18:31:40
George, on mine it is the supply for the blade and does keep the three point from working when engaged, but I still have to have the position lever for three point in the up position to have pump pressure for aux supply.
George
10-18-2003 19:49:03
 Re: Re: Re: Re: MF 202 Industrial: Value, Power st in reply to Tom, 10-18-2003 19:24:17
Tom,
I still have to pick up the tractor, so can't check, but sounds like I might not have a serious hydraulic problem; here's hoping.
Thanks again for the help...
