location of hyd. screen filter on 1958 mf85 ?
Gary Redinger
10-18-2003 13:38:21
before i pull the wrong access plates, can any one tell me which is the right one to get to the hyd. screen filter on my 1958 m.f. 85 gas.? the arms shudder coming up light, but with any implement on, they won't lift it off the ground, steering and p.t.o. are working good, also what should the proper settings be for the draft? Thank you from the eastern ozarks, Gary Redinger
L Tayes
11-10-2003 08:18:06
 Re: location of hyd. screen filter on 1958 mf85 ? in reply to Gary Redinger, 10-18-2003 13:38:21
I have a Super90 gas.Ours would shudder when lifting,the dealer said it could be from sticking valves in the pump.When i had the tractor pulled in two to fix the PTO clutch,I took the pump apart and cleaned all the parts,now the hydraulics don't seem to do it anymore.Hope it helps.
mojohn
10-18-2003 17:35:24
Gary
the hydraulic pump intake strainer is under the
flat plate that is directly under the hydraulic
shut-off valve.it will be on your left if you are sitting on the tractor.i just took mine off today and it is missing so i am going to order one.hopefully this will help you..
