165 multi power/front end
g cole
10-18-2003 05:26:36
Where is the hyd oil filter or screen located? Dwain how can I get in touch with you. May be intrested in parts. Thanks
Lee in MI
10-18-2003 07:04:55
 Re: 165 multi power/front end in reply to g cole, 10-18-2003 05:26:36
Multipower screen.
It's located in behind the front grill screen. Remove the front grill and oil cooling radiator and look up to the top left in front of the radiator, has a square nut on the bottom of the casister.
Hydraulic screen.
It's located on the hydraulic pump in behind the trans. To gain access drain down the trans oil about one gallon and remove the right side cover below the seat where the trans level dip stick is. Is located on the left side of the pump, some are safety wired. Not the handiest place to get at.
g cole
10-18-2003 15:16:42
 Re: Re: 165 multi power/front end in reply to Lee in MI, 10-18-2003 07:04:55
Thanks so much for the info on the multi power. Hopefully that will be it. It still wotks sometimes. Might be it
