MF35 Problems
Gator
10-15-2003 15:16:46
Can anyone please help. I have a MF35 gasoline and the only way I can get it to run is with the choke half closed. I have the points set at 22, plugs at 25, and timing set at 5 BTDC. When I open the choke completely it will run for a couple of seconds and the shutoff.
Part Time Farmer
10-16-2003 16:49:09
 Re: MF35 Problems in reply to Gator, 10-15-2003 15:16:46
Pine needles and other crap in the fuel tank gave me the same symptoms in a MF50. Even though the bowl is full of gas their was not enough flow to keep the engine running under load.
PTF
parts man
10-15-2003 19:02:33
Gator, you've got fuel problems. Check the flow at the carb. Clean and adjust carb if there's lots of fuel getting to carb.
R. Marg
10-16-2003 10:30:25
 Re: Re: MF35 Problems in reply to parts man, 10-15-2003 19:02:33
sounds like carb clogged up rebuild it and you should have it fixed
Craig In Colorado
10-16-2003 14:12:46
 Re: Re: Re: MF35 Problems in reply to R. Marg, 10-16-2003 10:30:25
Greetings,
In my few weeks w/ my 35, I've had some trouble (as though its out of fuel) similar to yours. It appears that scale has built up in my tractors gas tank and is restricting flow from tank to engine, choking or starving the engine down after a while. I'll be cleaning out my tank to try & remedy my issue.
Good luck, Craig In Colo.
