1130 MF PTO
greatbearfood
10-15-2003 13:03:45
Need to know how to remove pto and diagram
if possible
Charlie
10-18-2003 05:43:17
 Re: 1130 MF PTO in reply to greatbearfood, 10-15-2003 13:03:45
You can pull the PTO assembly off all in one piece and nothing will fall apart. Maybe you have some bad gears in the assembly.
greatbearfood
10-17-2003 12:35:41
THE REASON I NEED TO LOOK AT PTO IS IT KILL THE
ENGINE WHEN I ENGAGED IT TWICE. IT ALSO FEELS
ROUGH WHEN TURNING BY HAND THINK A BEARING WENT OUT. CHARLIE YOU SAID TO WATCH FOR NEEDLE BEARINGS
DO THEY COME OUT WHEN YOU PULL IT? I HAVE PULLED A
PTO ON MY 6080 ALLIS THIS SOUNDS SIMULAR, ARE THERE ANY TRICKS TO THIS JOB? THANKS FOR THE RESPONSE CHAILIE
Charlie
10-15-2003 19:28:46
You will need to do followig:
Remove about 20 gal of hyd oil, remove two large spring plates, remove sway bracket and chains, draw a sketch showing thrust washers, watch out for needle bearings(64 I think), if large seal is removed be carefull not to damage hole for seal you might try a tire tool(pry out). The PTO assembly is heavy, and I recommend you get four bolts(larger dia ones) about 6 inches long and cut heads off to use a guides to remove and install assembly. Pick up an IT manual or MF manual to use as a reference.
Why are you taking PTO assembly off? Charlie
