MF 135 perkins, diesel fuel leaks into engine oil
Jeff Smith
10-15-2003 11:25:43
I am frustrated by a diesel fuel leak into the engine oil pan, I checked to see if the leak was at the mechanical fuel pump but it was OK. I am not sure whether it is a seal leaking inside the injection pump or elsewhere. I am not even sure what model pump it is. Help!
dodgeboy
10-16-2003 17:00:53
 Re: MF 135 perkins, diesel fuel leaks into engine in reply to Jeff Smith, 10-15-2003 11:25:43
I have a MH444 diesel and found that the seal had worn a groove in the shaft of the transfer pump. This would allow fuel to leak past, into the oil, even with a new seal. I was able to relocate the seal to a new spot on the shaft by making an adapter to ofset it. Are you sure that this seal is not the problem?
If it is in the injector pump I'm not sure how to correct that. Ray
marlowe
10-15-2003 16:44:12
it is more then likely the pump seal and that is very common
